Supposed to be down rite awfull mate from what i have heard from friends and forums.
That's what I feared unfortunately!! Hope it doesn't go wrong then, or if it does, it happens within the year!!
And thats why I commented. I'm not in favour of restricting the legitimate use of the language. My point, when reading the sentence, is I understand it to mean the hardware has been devastated, overwhelmed. Not that its been sexually molested.
I have thought of a new name for this card
Superconned EVGA 512 MB 8800 GT with Crysis Which it will struggle to run blisteringly fast PCI-E retail.
Further apologies, I seem to have diverted the thread!!
Anyway, I do have something to add now!
@ willhub, you're clocks are still pretty good, and are over the EVGA superclocked specs. There's no guarantee that the EVGA will clock further than anybody elses.
My view is changing with the warranty situation though. Before, I used to scoff at the 10 year warranties being touted by BFG and the like, but having had to avail myself of it recently, I'm now a big fan! BFG turned my RMA around inside a week, and when I read the stories of XFX customers being given short shrift, it makes me glad I chose a BFG.
I've got an Asus GT now though, does anybody know what their RMA service is like?
My view after reading the EVGA cherry picking thread is that you should never buy a vanilla EVGA card.
The reason?
They test them to find ACS3 and Black Pearl cards and the ones that fail get thrown back into the normal card pot. Hence they can't run stably past 650Mhz.
A top end pre-oc card from EVGA is fine cause at least you have the gauranteed stock speed plus it still might go higher. (EVGA top 8800GT runs at 700MHZ)
But that leaves the normal pot of vanilla cards short of good overclocking cards.
For example, all 8800GT's made by Foxconn etc so all the same.
Say 20% can run past 700Mhz.
EVGA cherry pick a large chunk of these to be their pre-oc 700MHz cards or maybe all of them if the pass ratio is low.
That will mean that only a very small percentage or even none of the vanilla EVGA cards will overclock well. Maybe best to avoid the 650Mhz OC ones as well as these might contain a lot of cards which failed at 675Mhz and 700Mhz.
Anybody see a flaw in my logic?
Nah it isn't really at that resolution, new drivers boosted performance loads for me on my GTX though and probably do for the GT.That's pretty impressive tbh (if it's true)
(all other games work, Timeshift is the latest game I've tried and it's perfect). World in Conflict is fine with my 2900 though so it's nothing to do with my systems stability. I thought there would be no problems with the GTX under XP as well
.Just to say on high detail at 1280 X 1024 with no AA and in DX9 mode the EVGA Superclocked 8800 GT averaged 36.4 FPS in Crysis in a benchmark done in its review by Hardwarecanauks (or however it's spelt)
What driver you running now. I'm using the 169.04's but I was thinking about the new WHQL 163.75's?. Any advice?. I'm testing my m8's 8800GTX and every driver I try makes World in Conflict crash or artifact on XP(all other games work, Timeshift is the latest game I've tried and it's perfect). World in Conflict is fine with my 2900 though so it's nothing to do with my systems stability. I thought there would be no problems with the GTX under XP as well
