Hi Guys,
I've just built a new PC and I'm getting no output from my PCIE ATI Radeon X1900XT Graphics Card!
I've checked all cables and everything is plugged in (DVI-D to DVID connector, and the 6 pin power plugged into the back of the card).
When I boot the card on I notice that at the top right corner of the board two on board lights come on as soon as the board powers up: T_FAULT and EXT_PWR
http://ati.amd.com/products/radeonx1900/radeonx1900xt/specs.html
Can anyone help me?
My Setup:
Gigabyte P35-DS4 Mobo
Core 2 Duo 6600
2 x GB Crucial Ballistic 8500 1022MHz
OCZ 600W ATX2 PSU
4 x Seagate .10 500GB HDD
Can anyone help me?
My Setup:
Core 2 Duo 6600
OCZ 600W ATX2 PSU
, Double check the cards seated & the power cables are firmly attached (you've probably already checked several times but I've got to ask) , Other than that you need to test your card in another system if you can as a faulty PSU or damaged PCI-e plugs is rather unlikely, also if your PSU is modular try a different output &/or lead.
