Permabanned
- 19 Jun 2007
- InURmama
Wanting to bring something new for the holidays OCZ has updated its Reaper memory series. Named ReaperX, the memory starts from the well-known Reaper HPC (Heat Pipe Conduit) design and ends up using a dual metal heatpipe formation to effectively offload heat and increase stability of memory modules.
The new ReaperX HPC (Heat Pipe Conduit) modules offload heat with extreme efficiency due to a new dual copper heat pipe design. Each memory chip is in direct contact with a thermo-conductive pipe that guides the performance robbing heat away from key memory components and quickly dissipates it through the aluminum fin array.
For a first try, the ReaperX is handling DDR2 chips and takes the shape of either a 4GB dual channel-ready kit or a single 2GB module. Certified to work at 800 MHz with 4-4-3 timings, the ReaperX kit features EPP (Enhanced Performance Profiles) and comes with a lifetime warranty.
http://www.tcmagazine.info/comments.php?shownews=16710&catid=2
