Audio recording queston???
18 Oct 2002
Smoke-On-Trent
Does anyone have any idea how I can record a voice message left on my mobile to pc? I know I could put the speaker by the mic but could really do with keeping as much of the quality as possible. crag.
Headphone out on the phone to your line in on your soundcard? :confused: Mini-jack to Mini-jack needed.
Lol simple answer to a simple question, mine does the same, my headphones plug into a wire which connect to my phone 1.5mm pin to 1.5mm pin needed... easy peasy..
I tried this before some time ago and I got the mobile noise you get through audio equipment, you know the noise. I was wondering if it's possible to access it over the web using software????
Obviously wernt set up properly, its possible dude, just plug it up and get the software to record it...
not sure how, hire a condenser microphone :) would do the trick.
True. Something like, say, a Neumann U87 would be perfect for recording those subtles nuances inherent in compressed, 8-bit sampled audio with a glossy top-end of 3KHz :p. Any cheap computer mic will do for recording, but a direct out will naturally produce superior results as you're not battling with ambient and handling noise.
:D
