OEM VISTA and Harware changes?
4 Aug 2005
hi guys i've registered my OEM copy of vista home premium x64 for a while now, and i know that there is a draw back about changeing your hardware may affect it's validity.
i was wandering what hardware components will and will not affect windows activation?
i know that ram/gfx cards don't as i've change both of these since i activated vista.
its academic
when it comes up and says it needs reactivating, even if you've formatted several times, ring em, go through the activation crap, job done
biggest hassle is entering the 42 digit code
so if i changed for example cpu/mobo then they would just give me another code? i know about this i've been through it once already after a update it suddenly decided my vista wasn't valid although it was with the same hardware i activated it with.
Hey harris1986, their is a slight difference between being activated and being licensed. If you have the OEM version of Windows Vista, like yourself, you can change any system component in your machine apart from the motherboard and you will still be licensed. You may have to re-activate Windows Vista after a hardware change but you will still be allowed to activate Vista and will not be breaking the EULA. Now depending how significant the hardware change is, for example updating the BIOS of your motherboard, you may have to ring Microsoft up yourself because online activation may fail. If you do have to ring them up, just tell them what has happened and they will happily activate your copy of Windows Vista for you.
If you change your motherboard, (We are not talking about replacing your motherboard under warranty here) for a performance upgrade then I am afraid you will have to purchase a new copy of Windows Vista. If you don’t do this and buy a new motherboard, the only way you will be able activate the copy of Windows Vista you already have is to lie to Microsoft and come up with something, now if they give you a new code, you now may be activated but you certainly are no longer licensed and would have just broken the EULA.
Some of you may say that, Microsoft themselves gave me a new code so how can i be violating the EULA. They gave you a new code because you had lied to them, if you said the truth and told them you changed your motherboard for a performance upgrade, they will tell you to go out and purchase a new copy of Windows Vista. Theirs a certain amount of trust Microsoft give its customers, if you wish to abuse this that is up to you.
As you can see, their is also a difference between what you can physically do and what you can do legally. :)
You can probably blag it with the old motherboard failed line.
You can but you will be violating the EULA. :p:)
