Permabanned
- 19 Jun 2007
- InURmama
Correct, esp for a CPU Dependant game (so says the CEO), the peep does not seem to have much knowledge on subject though as the low CPU useage is probably our issue.
Or, you can buy the game now, enjoy it now and then play it again with improved visuals once the hardware has caught up.
So you WANT 100% cpu load on both cores?
WTF LOL
Sorry but I think the way they have done it is brilliant.
Should scale fabulously!
Remember you lot are really really really REALLY GPU limited...
I'm pretty sure the game is only CPU limited in regards to advanced physics, etc. All the breakable objects and buildings, the environment, etc.
He certainly isn't blabbering tosh, Helmet.
So what do you want the game to do with the CPU cores then?![]()
No, I mean the low CPU usage is bad. Even the most simple of games with proper implementation should be using as much CPU as possible.
WTF LOL
Did I say that, you dont have a clue m8, the Game is supposed to be CPU Dependant, in my Case and many others it used hardly any of 1 Core and next to Nil of other Core(s).
You really need go read up on the Crysis interviews before blabering Tosh,
People need to realise that they designed Crysis so that it will still look good and be taxing in like 2 years. They wanted it to last, and it will.
As of yet, no GPU is really powerful enough to run it at high res, with AA and all settings on high / vey high.
However they will be. I find it doen't look to bad without AA tbh
No-one will play this in 2 years time, we'll be busy with Alan Wake 2 and FarCry 3.
They should have made this for now, and they havent, and for the record, dont get your hopes up about the full release having better performance, it wont!
Use them, when it's needed (which mine seems to be doing just fine). For example if your FPS is really low in a physics/AI heavy part of the game and your CPU is only working at 30% then surely there is the potential for the game to run faster.
You seem to have a really bad attitude problem. What Concorde Rules has said is right, from your quote below Raikiris quote, you are basically saying that you want 100% CPU load. We can only go on what you are posting.
Post a bit more clearly in the future and then this misunderstanding wont happen.
Anyway Swapping a 8800GTX for a 8800 Ultra is pretty hard to justify.
