Amazing Weekend Special Deals!!!
OcUK Staff
17 Oct 2002
OcUK HQ
We have a treat for our customers and forum users who are on the hunt for an amazing deal all with ample stock and available for next working day delivery.
OCZ 4GB (2 x 2GB) PC2-5400C5 Dual Channel Vista Upgrade Gold Series DDR2 (OCZ2VU6674GK)
The new PC2-5400 Vista Upgrade edition is optimized for perfect compatibility for those transitioning from Microsoft Windows® XP to Vista™. The OCZ Vista Upgrade series has gone through stringent testing with the full spectrum of Vista versions to deliver a perfect balance of memory performance and stability across the full range of applications. As a Vista up-grader, the PC2-5400 4GB dual channel kit will provide excellent memory bandwidth and deliver the most efficient operation possible, ensuring the best possible gaming and productivity on Vista systems. Each memory module features a proprietary OCZ XTC (Xtreme Thermal Convection) heatspreader for the most effective heat dissipation. Furthermore, each OCZ Vista Upgrade module is 100% hand-tested for quality assurance and compatibility and is backed by an industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
* XTC (Xtreme Thermal Convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. In this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. At the same time, mechanical stability is maintained.
- 667MHz DDR2
- CL 5-5-5-15 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- Copper Mirrored XTC Heatspreader*
- Lifetime Warranty
- 1.8 Volts
- 240 Pin DIMM
- 1.85V EVP - OCZ's unique Extended Voltage Protection feature allows PC2-5400 modules to handle voltages up to 1.85V ±5% and still be covered by our Lifetime Warranty.
Previously sold at £94.99 +VAT (£111.61 Inc. VAT)
Now Only £59.99 +VAT (£70.49 Inc. VAT) (£41.12 Saving!!)
BUY NOW!!
Leadtek GeForce 7600 GT 256MB GDDR3 HDTV/DVI (AGP) - Retail
Experience extreme HD gaming and video on your PC with a Leadtek GeForce® 7600 GT graphics card. Featuring the award-winning GeForce® 7 Series architecture, this graphics card delivers smooth, realistic gaming at ultra-high resolutions. Additionally, the GeForce® 7600 GPU by NVIDIA® brings high-definition, home-theater quality video to the PC through the acclaimed NVIDIA® PureVideo™ technology. Factory overclocked core and memory clocks gives an extra boost in performance at no extra cost.
- GeForce 7600 GT Core running at 560MHz
- 256MB GDDR3 Extreme Memory running at 1400MHz
- 12 Pixel Pipelines
- Designed For Extreme HD Gaming – Delivering Ultra Realistic Gaming Experiences
- Dual link DVI support (Upto 2560x1600 resolution)
- Shader Model 3.0 Support
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- Bundled with Serious Sam 2 and Trackmania Nations PC Games!!
Previously sold at £59.99 +VAT (£70.49 Inc. VAT)
Now Only £53.99 +VAT (£63.44 Inc. VAT) (£7.05 Saving!!)
BUY NOW!!
Point of View GeForce 8800 GTX "MotoGP & Settlers Edition" 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
The 8800 series is the world's first DirectX 10 graphics card with full Shader Model 4.0 support. It delivers unparalleled levels of graphics realism and film-quality effects. Even more, it also supports the NVIDIA Lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. Built for Windows Vista™, the 8800 series ensures the best possible performance when running the Windows Vista 3D graphical user interface. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported. The WinFast® PX8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported.
- GeForce 8800 GTX core running at 575MHz
- Shader Clock Speed of 1350MHz
- 768MB GDDR3 Memory running at 1800MHz
- 384-Bit Memory Interface
- 128 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 36.8 billion/sec
- Memory Bandwidth: 86.4GB/s
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- Supplied with MotoGP'07 PC Game & Settlers 6:Rise of an Empire PC Game
- 3yr Warranty!
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
Previously sold at £264.99 +VAT (£311.36 Inc. VAT)
Now Only £249.99 +VAT (£293.74 Inc. VAT) (£17.62 Saving!!)
BUY NOW!!
HIS ATI Radeon HD 2900 GT SILENT Heatpipe 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
The HIS Radeon™ HD 2900GT unleashes the power of DirectX® 10 with awesome performance, stunning visual effects and more dynamic interactivity than ever before. Surpass reality with easy CrossFire™ scalability, built-in HDMI and 5.1 surround audio for an immersive HD Gaming experience. HIS Radeon™ HD 2900GT delivers ultimate realism and performance at all resolutions in high dynamic range from a 2nd generation unified shader engine. The HIS Radeon™ HD 2900 powers today’s titles and introduces a new platform for upcoming DirectX® 10 games. Our next-generation unified shader engine with 240 unified stream processors, a 256-bit memory interface, CrossFire™, game physics, and built-in HDMI with multi-channel 5.1 surround audio establishes a new level of performance and technology designed for discerning gamers. HIS Radeon™ HD 2900GT delivers ultimate realism and performance at all resolutions in high dynamic range from a 2nd generation unified shader engine and easy CrossFire upgradeability. Built-in with HDMI audio and video, HIS Radeon™ HD 2900GT enables a one-plug big-screen HD gaming experience with ATI Avivo™ HD video & display technology with advanced high definition features.
- Powered by Radeon® HD 2900GT GPU
- Superscalar unified shader architecture
- 240 stream processing units
- 256-bit 8-channel memory interface
- Comprehensive DirectX® 10 support
- Integrated CrossFire™
- Built-in HDMI and 5.1 surround audio
- Dynamic geometry acceleration
- Game physics processing capability
Previously sold at £104.99 +VAT (£123.36 Inc. VAT)
Now Only £99.99 +VAT (£117.49 Inc. VAT) (£5.87 Saving!!)
BUY NOW!!
Sapphire ATI Radeon HD 2900 GT SILENT Heatpipe 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (21123-00-40R)
Erecting Worlds of Wonderment! The “Big Bang” creation of your virtual world erupts from the SAPPHIRE HD 2900GT delivering full acceleration of the latest in DirectX® 10 and OpenGL applications. Your only limitation is your own imagination! 1080p HD gaming breathes life into characters and pumps adrenaline through the veins of enthusiasts around the globe. Step into a world of HD content playback with HDMI support provided with SAPPHIRE HD 2900GT. Experience next generation hardware for Windows Vista™, OpenGL and DirectX® 10, while allowing for easy CrossFire™ multi-GPU upgradeability, to run the hottest titles of today. Delivering a fully loaded HD feature-set including support for ATI Avivo™ HD, HDMI connect ability, HD Audio and Blu-ray/HD DVD decoding, the SAPPHIRE HD 2900GT eclipses the demands of the performance hungry Media PC. The SAPPHIRE HD 2900GT with its impressive hardware specs such as: the industry anticipated ATI Radeon™ HD 2900GT GPU and 256-bit memory interface will leave even the most battle hardened with a tear of joy in their eye.
Previously sold for £109.99+VAT (£129.24 Inc. VAT)
Now Only £99.99 +VAT (£117.49 Inc. VAT) (£11.75 Saving!!)
BUY NOW!!
Samsung SM-245B 24" Widescreen LCD Monitor - Black
Imagine having elbow room on screen. That’s exactly what you get with the Samsung 245B series of widescreen LCD monitors. Wide 16:10 aspect ratios let you multitask, with room for more than one application at a time. The extra room also makes working with graphics programs and multiple tool palletes easier. An ultra-fast 5 ms (G to G) response time is perfect for motion graphics editing. And exclusive MagicBright 3,™ MagicColor™ and MagicTune™ technologies give you complete control over outstanding color. All the color. All the room. With the Samsung 245B, it’s not hard to imagine.
- Viewable Area: 24” Widescreen (1920x1200 Resolution)
- Interface: Analog / Digital
- Response Time: 5ms
- 16.7M Colours
- Contrast Ratio: 3000:1
- Viewing Angle (H/V): 160°/ 160°
- Brightness: 400cd/m2
- Height Adjustable stand with tilt & swivel
- 3 Years On-Site Warranty with Samsung
Previously sold at £269.99 +VAT (£317.24 Inc. VAT)
Now Only £259.99 +VAT (£305.49 Inc. VAT) (£11.75 Saving!!)
BUY NOW!!
More importantly, how well do they clock?
Can they do 6400?
I couldn't find many reviews, but the one I did find said it wouldn't go that much over stock, only to ~775 which isn't quite 6400. Saying that, the comments on OcUK say it will do 6400 OK.
Hi there
You'd be very unlucky to get a set that did not do at least 850MHz to be honest, so 800Mhz should be doable with around 2.1v
Hi there
You just know when you make a statement like that that someone is bound to buy a set and moan like hell when they won't overclock, don't you?
Let's say I buy 100 sets, how many would you say will clock to 850MHz?
HI there
Impossible to predict, there will be some bad apples that no doubt will do 750MHz and there will also no doubt be great ones that hit 900MHz.
Overclocking is an art and mileage differs depending on the hardware your using, yield of the hardware you have and the skill of the overclocker involved.
Fact is this memory might do 850MHz fine in one motherboard, but in another might only do 750MHz.
If OcUK was guaranteeing an overclock on this part then it would be very clearly stated on the website, were not offering any guarantee but quite a few people have purchased this kit from here and all left positive feedback on it.
Some bad apples? i had Gskill ram replaced like 3 times in total then got a 2gb set upgrade for free because of all the problems i was getting running them at the correct speed, and they still wont.
someone said it may a problem with my mobo as the ram was tested fine by gskill before it got to me.
sods law as usual, never had any luck overclocking out of any system ive had.
next upgrade ill be looking out what to buy even more so :)
posted as a review for the memory
wouldnt you need 7 x 500 (1000MHz) for 3.5GHz:confused:
3dmark score of 15000 lol so who is this ILYE
I think those are made up actually. Almost none of them match up to user names on these forums. It's not conclusive proof, but there's enough evidence of spoofing to make me doubt anything I read in those reviews. Plus, it'll never actually let me post anything. Hmmmm.
