http://halflife2.filefront.com/file/FakeFactorys_Cinematic_Mod_5;84027
Edit: some more mirrors (if filefront gives you 100kb/sec)
http://kaese-hosting.info/dlm/comment.php?dlid=2 <------- this site has a torrent file ( I used it, and overnight Ihad it downloaded)
http://www.hlportal.de/?site=files&do=showfile&file_id=631#mirrors <-----german site with 4 mirrors.
This is the cinematic mod which finaly came out for episode 2.
Even though the characters don't look like the original ones, they still look insanely detailed.
How nicely done is this:
http://halflife2.filefront.com/screenshots/File/84027/11.
Anyways, if you wanted a reason to play episode 2 again, this could be one.
1.1) Memory requirements
A minimum of 3 GB RAM is needed for playing on maxed texture/shader settings.
A minimum of 2 GB RAM is needed for playing on medium texture/shader settings.
You can try the mod on 32 Bit, but most likely you need to set texture
and shader details to medium or low for crashfree play (it will still looks
good at medium settings). 64 Bit users are able to play with all settings
maxed out, as the engine can use all available RAM for allocating memory blocks.
1.4) Software requirements
You need a full installed STEAM with the following full installed and unlocked games:
+ Half-Life 2
+ Half-Life 2 Episode One
