Any cooler will do the job to be honest as the temps are ridiculously low...
I brought a Zalman cooler which also cools the mobo but covers 2 of the ram slots (cant remember name) and it runs the cpu at 32 degrees idle in Vista x64 and 55 degrees under heavy load after 8 hours and thats with the multiplier whacked upto 3.3ghz overclock.
My view:-
If you want a good gaming cpu which will handle anything you throw at it with ease for a cheap as chips price of £80 then this is the chip to go for...
I know a lot of people are saying "wait for the quad core" but as far as performance goes it isn't going to make much of a difference unless your planning on getting an extreme end rig for top end crysis.
As for the 6400+ BE i'd say ignore it.
The 5000+ easily overclocks above the stock of this chip and performs at a lower voltage and temp!!!
My view:-
