As per title really, am running vista home premium 32bit and have 4gb installed (yes I know it wont recognise the full 4gb) but even so, any ideas why it would be limited to 5.3 on the scoreboard? Can only 64bit OS with 4Gb or more get 5.9?
Its the Windows Scores! Ignore and just use it, they are crap anyhow.
so you have inside knowledge of what tests ms base the score on?
Everyone might as well ignore all the other benchmarks and minor adjustments of cas, ras etc if thats your pov of a 0.6 difference between his setup and similar setups![]()
using whatever methods of measurement microsoft choose to use
No but what info does Vista rating give you, seriously give me one count it gives you? What sufficiently intelligent person would actually use that crap? Go take an everest memory benchmark, or Sandra memory test, or any friggin useful test, but do not judge anything like Vistas insanely crappy ratings. It's the worst Microsoft decision ever, worse than DRM even.
I went from 4GB of pc3200 to 4GB of pc4000 & my pc became a stuttering mess.
I ran the vista rating & it showed me exactly where my problem was with the very low mem score and figured the auto mem timings ain't doing the job for this mem but hell no! i should have used everest & Sandra first & done some heavy benching right![]()
Actually, the mere fact that you had the problem after changing your RAM should have been a pretty big red flag. Furthermore saying that the Vista test is good for debugging RAM is erroneous as there will be plenty of ram errors it wont pick up.
For that type of thing you use Memtest86+.
"Auto" ram setting with high performance RAM is a bit silly tbh as most RAM doesnt have its best settings programed into the SPD, my Cas 3 667Mhz is rated to 5-3-3-15 by SPD, but 3-3-3-10 as spec.
@ Final8y, Why you even arguing, I did not see Talrinys insult anyone in this thread apart from have a dig at MS.
The Vista Scores are nothing to loose any sleep over, so get over them.![]()
