After a cheap PCI-e card
Permabanned
25 Aug 2007
I am after a cheap PCI-e card to play some games. I know i will only be able to play at low settings so do you think this card is ok as my budget does not stretch to the better cards at the mo:
256MB Leadtek 7600GS CO, PCI-E (x16), Mem 700 MHz, GPU 490 MHz, 12 Pipes, D-Sub/Dual Link DVI-I/HDTV £43
Any good?
Any good?
What games?
Is this one better / worth the extra:
256MB XFX 7600GT 'Fatal1ty' PCI-E(x16), Mem 1600MHz, GPU 650MHz, 12Pipes, Dual DVI/HDTV SLi Passive £55
Was going to say can you not stretch to the GT as it has GDDR3 RAM so it runs quite a bit faster...
Im not sure how much better that makes this exact card but when I compared my brother's old 1600Pro against my mates 1600XT, the XT (having GDDR3) was a hell of a lot better.
