Hey guys,
Just changed the spark plugs, and realised mid way through that the gap was different to my old ones....and my car has 2 listed gaps, 1mm and 1.3mm depending on age etc. The motorfactor said that mine should be 1.0mm, but my old ones are 1.3mm
To cut a long story short, it's running very slightly rough at idle and I can't get the 1.3mm plugs until the morning, but ideally need to do a 50 mile round trip tonight....would it damage the engine to do it?
Before anyone says it, you can't change the gap on NGK platinums :|
Cheers,
Tom.
Cheers,
Tom.
