4GB Corsair XMS2 800
26 Oct 2007
Hi Guys,
Ive been told by another member that I cant run my memory between 723 and 838 mhz as it wont post, and hes right in saying that because I just could not post at 800mhz (I have a gigabye n650 ds4 board).
Im currently at 667. What would you guys recco I run this memory at, and what should I change my timings to?
Cheers for your help
Are you running the latest BIOS? I *think* someone said the issue had been fixed in the ASUS 650i board with a newish BIOS. No idea if Gigabyte ever got around to sorting it out.
Hi Cob, I checked and it is the latest F7 bios.
It certainly wont post at 800mhz, Ive got it at 667, I dont know what to try next, maybe 700 :S
I would stick it on 720mhz and see if you can lower the timings a little (I assume they're meant to be 5-5-5-15 @800mhz).
I have no hands-on experience with the n650i chipset, but try upping the-
NB/HT link voltage
FSB Voltage
Southbridge Voltage
by 0.1v each and see how you get on. If that doesn't work then set the CPU Voltage to 1.375v.
NB/HT link voltage
FSB Voltage
Southbridge Voltage
Thanks COB, it posted at 720 on the memory, do you think I can go higher :S
Ill give those settings a try for the OC, shall I just leave the others on auto?
