5x100, 35+ offset.
Just been completely refurbished at a cost of £300 which included straightening, welding(if needed) chemical stripping, basecoating and finally finished in satin black.
Ill have some pics up soon, however all im really bothered about is what they would fetch? I believe this is the same fitment on the VAG range as it is to the Subaru range...
This is all assuming i do sell them, as they look rather spiffy and if i can get some 19inch rubber without costing me an arm and a leg i may keep them.
thanks.
thanks.
) - select manufacturer and it will tell you the PCD of their cars. Select PCD and it'll tell you everything with that PCD.
