which mobo to pick asus P5K-E or asus Asus P5N32-E
17 Apr 2007
This is whats going in it
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail
Asus GeForce 8800 GTX HTDP 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
i will not be overclocking, i want it for gaming will be running winxp pro and maybe later vista, and can you point me to the best 2gb ram for use with those 2 boards.
And i really want it to run stable with no messing in the bios well not too much.
p5k-e is defiantly more stable with less issues as nforce boards.
I'd go for the P5K-E.
However if you don't want to overclock, why do you look at expensive asus boards with top chipsets anyhow, you could just aswell buy a cheap ASrock board with a 945 p chipset, they are still perfectly stable @ stock as most boards are.
Okay, then go for the P5k-E imo from those 2, more stable chipset in general, more stable&featured&compatible sata controller, and intel chipsets usually clock higher than nforce.
there is 3 sets of geil memory doesn't matter which?
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Black Dragon DDR2 Dual Channel Kit (GB22GB6400C4DC)
800MHz RAM Speed, CAS 4-4-4-12 Timings, 1.9-2.0v VDIMM
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
800MHz RAM Speed, CAS 4-4-4-12 Timings, 1.9-2.3v VDIMM
GeIL 2GB (2x1GB) PC2-6400C5 800MHz Value DDR2 Dual Channel Kit (GX22GB6400DC)
800MHz RAM Speed, CAS 5-5-5-15 Timings, 1.8-1.9v VDIMM
You could go ocz ddr800 cas4 or cruciall ballistix alternitavely, I've had no problems myself with Geil Ultra low latency ddr800 on my Asus boards.
The Geil Ram works fine on my P5K-E, for other type of memory as snowdog said the OCZ and Cruciall are also good... OCUK normaly has an offer on one of the better brands of RAM
