Image hosting sites
I'm amazed that there doesn't seem to be anything that suits my needs.
All I'm after is something like imageshack, which supports gallerys/albums for organising your pictures, and generates thumbnail code for posting the pics in blog entries.
Sounds simple enough to me, yet there is nothing that has both of those things. Not even in scripts I could run from my hosting. Closest thing is celerondude's uploader script, but I really don't like that at all.
Seek, Zenphoto could probably do what you want with a small bit of tweaking to the template to create the forum code for you to copy / paste.
photobucket.com does that.
I feel like I never said this.
But I did.
Well I guess you feel like that because you don't read posts.
I already said I'm looking for something which returns thumbnail code for posting images on my blog.
No it doesn't. It has decent enough gallery/folder options, but it doesn't give thumbnail codes.
I've just tried it out and added a forum code box to my Zenphoto install, it was fairly straight forward so if you need a hand with it, my email is in my trust. :)
example: http://cheezyblog.net/gallery/photography/_MG_0515.jpg.php
Thanks, but I had to ditch zenphoto as an option because of the way it handles thumbnails. It's thumbs are not small versions of the whole picture, but cropped versions. Your picture "_MG_0372" featuring a boy in the snow is a prime example of why it wouldn't work for me (in the thumbnail view he has his head chopped off).
A shame, because it would otherwise be an ideal solution.
