Phenom, good sometimes, not so good others
Caporegime
18 Oct 2002
So far mixed bag, quite a few reviews.
anandtechs reviews against a penryn and kentsfield
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3153&p=11
but seems to get it wrong IMHO.
there are things like, old school apps they've benched with for years to do encoding. the only newer encoding review, the x264 one, its basically clock for clock performance for all results which is great. in the older stuff its slower, but its still very fast, more than fast enough for anyone but someone who encoded 24/7. but anandtech kept saying that intel won because their chips were priced under amds.
but in reality, we'll all overclock them so just like we prefer to pay for a E6600 and clock it up, we'll be getting the £145 chip and clocking it up as far as possible, probably to same speeds as the rest. in gaming, the benchmarks are at very low res/detail, and older games its the difference of hl2 at 153 vs 180, with amd losing, but again at high res they would give same numbers. but crysis, at low res was giving similar numbers. now being crysis i would say the gain could be gpu limited more, but i'm not so sure tbh. its still very low res and most likely very low detail meaning less gpu limited.
i tend to get the impression, theres only so much brute force you need, newer programs, newer games, newer encoding tends to do things better, smarter, to higher quality. that needs better smarter cpu's, brute force is to make older more basic programs run faster. but theres a point where you just don't need more speed on old stuff.
the 3 issue width is the same as older k8, while intel have a 4 width(i think even 5 for things like superpi, but only on very specific usage which is difficult to get to). which is fine, harder to run apps often only fill the core 2 duo with 3 instructions, less is possible on both chips. To a point had they added a 4th, it would give them more brute power, which would result in a lot of programs being faster, but newer programs, more complex, would still only routinely fill the 3 issue width rather than 4.
Its going to be seen as bad, when frankly the use in games will not be any different to intels(at normal resolutions), even dual core intel/amd. i thinka phenom + board will end up cheaper than an intel equivilent, a quad crossfire top end 790fx is as cheap/cheaper than a sli/dual crossfire x38, let alone how much a x48 will cost.
It all feels like a stop gap to the next big jump from both big companies to 8/16 cores with a few of those specific cores, basic gpu, maybe ppu, maybe split up the cores a bit more sony/cell like, so you can choose a fpu or int beast should you want.
the other issue would be a fairly damn new chipset for amd, vs a x38/p35/965 that have changed very very little and had a long time to get the most performance possible out of it. wonder if mobo's will improve much.
[h] are saying the black edition 2.3Ghz will be the same price(well probably bumped up £5 in stores i would think) for an unlocked core that h reckons they can get to 2.8-3Ghz easily, i would think that will be on air aswell. personally i've never had a chip on air/water thats needed a higher multiplier in the past 5 years, fsb and lower multiplier has always been the case for me. but its a nice touch to make it same price and offer the enthusiast the option should we want it. £145 for the 9400 and 9500 apparently in both black and normal edition at £159.
also, their overclocking tool looks god damned brilliant tbh. it seems to basically have every single option every little tweak program has offered us, memset, cpuid, clockgen and the rest all in one app supported by them.
i think every, or almost every single bios option is available in windows. though obviously, if thats more stable than bios is yet to be seen, anandtech decided to only overclock through the tool which might have affected their top stable overclock(2.6Ghz despite being able to get into windows at 3Ghz). not sure.
Another review at Hardocp
AMD Phenom & Spider & Intel QX9770 Comparo
As stated on page one, the Phenom is a disappointment. It comes close to meeting a clock for clock battle at 2.4GHz or so, but still just does not do it. Phenom has not caught up with what Conroe had to offer so many months ago. As the clocks scale, Phenom begins to look even worse against the new Intel Yorkfield processors. Given those processors are priced about $700 more than our Phenom 9600, but the lower end Intel Yorkfield cores are coming and will be very close in price to our Phenom 9600 and will simply run away from it in clock to clock benchmarks.
its not looking great, i'm not sure why they didn't do full sse4. there seems a noticable lack in performance when sse4 comes into play, for instance in crysis with high physics phenom does well against the kentsfield, but significantly worse against penryn which will most likely be sse4.
but then, maybe just better compilers to use sse4a better are needed, who knows.
but its been the case for a long time, if you're a gamer, 2.4Ghz dual core of any kind is ample for any game out right now, a 2.4Ghz x2 feels much the same as a 3.5Ghz penryn when you're at whatever res your gpu handles well. for gaming, much more than £50 on the cpu is a waste at the moment and for a while.
gpu upgrade first for most of us here, and i think with the 3850/70 prices, a 2nd gpu would be the next viable upgrade now.
what needs to be seen is, when exactly we see 2.8Ghz stock phenoms, Q1 could mean right after xmas, they are just stockpiling and binning the new b3 stepping now, or could mean end of march. i get the feeling they aren't too far off though.
what they really need to be doing for launch is the 9500 at something like £125, making it a very viable and cheap quad core alternative, and making the 9600 at most £145, but more like £135. tbh, people like dell the £6 difference between a phenom at £159 and q6600 at £165 is massive, and across a 200k computers gives them a big saving. but to the end user, who will be the ones telling everyone what to go buy, that £6 isn't enough of a saving.
Wrong, I'm going to get one to put in my server and for stability's sake it won't be overclocked at all.
I know this is an overclocking forum and most people are all just interested in overclocking but look at the bigger picture and a lot of people will not just be looking at overclocking these chips. Four stable cores is a lot more desirable to me than overclocked, hot, reckless ones :)
why not just get a q6600? Can get a used one for cheaper
well i meant most, not all,but then my q6600 is at 3.8Ghz, completely stable, i ran 4 dvd encodes yesterday on 2 cores while playing a game at almost normal speed on the other 2, basically every single part of my system, bar the dvd drive, was under load, thats after over a month of daily use to do mostly gaming.
overclocked != unstable.
people that overclock and get as far as a cpu-z shot saved before crashing are fine, but not me, i get my max 24/7 overclock and keep it there, completely stable to any use.
but in reality, for a server, what would it be doing for you that it needs 4 cores? a lot of people have a home server, that goes as far as only being cpu loaded to the extent the onboard nic needs to give best speed. or you might be running websites from home, thats fine too, might need some juice there.
but 99% of people that use a computer at home the most intensive thing they do is gaming. the number of people who actually use 3dsmax for work at home, or other intensive 3d rendering are in the 100's, maybe 1000's to be honest. sure a few of us play around with stuff but its not exactly serious.
soooo....Phenom sucks, big surprise lol
well i was trying to indicate that, it seems to keep up very well in newer more complex software. it goes clock for clock performance for x264 encoding, while being beaten in divx, despite xvid being used more than divx. but amd could have added raw horse power(4 issues per clock instead of 3) but the fact is in x264, crysis, other more complex things it matches the kentsfield. do you really need 180 fps in hl2 over 150? the extra power amd could have put in, at heat, power, transistor, size, price cost would have added very little for me, an extra 20% in games that are already way more than fast enough, and very little in more complex programs if anything.
meh, its hard to explain, trying to think of a good metaphor but can't.
the simple fact is even at stock in gaming you'd be hard pushed to see the difference in any game. in most apps that will be the case. but in benchmarks , intel is faster, which is why amd really needed to be more agressive for the channel sales market. £6 less for the 9600 with unlocked multiplier isn't going to sway most people over a Q6600, £20 less would though.
I feel bad for AMD, I really do... And I hope they will recover from all this
I read their overclock page somewhat different. 3Ghz unstable, 2.8Ghz unstable, 2.6ghz stable enough for benchmarking.
However it didnt scream the 'confidence' of Intel overclocking where long term stability with high levels of overclock is very high.
For example, at 'stock Vcore' I can overclock my E6700 to around 3.4Ghz its stable enough for benchmarking to give 'performance' indicators, but if I try to use it for anything sensible it will crash out, give incorrect results in Prime95 etc etc... Its benchmarkable, but its not stable. Drop it to 3ghz and its 100% stable left running 24/7.
(Note the VID on my E6700 is one of the low ones... my Badaxe feeding just 1.2V into the cores, and I've not bothered to do the debug mod on the badaxe to unlock the improved Vdroop mode or cpu voltage override, so when its working at full load that 1.2v drops even further. Im quite sure with reduced vdroop, and 1.3V my E6700 would clock even higher :P)
I think people buying phenom as an 'overclocking' chip will be disappointed by the results. I dont believe it's coincidence that AMD lowered the 'stock' clocks just before launch. While im sure that AMD will improve the process and get higher clocks out of the chip, but will it be enough. Intel too are pushing forward and by all accounts Penryn 'could' reach 4Ghz 'stock' speeds if AMD put any kind of pressure on Intel.
Come on AMD.. we need an ACE, otherwise prices will start to rise again, and intel will have less reason to release faster processors.
Stock performance is generally on a par or *very* slightly below the Intel Q6600, but this stepping won't compete when it comes to overclocking. Aside from scaling back it's release speeds, AMD have now pulled the 2.4MHz part altogether because of a TLB errata which causes it to lock up under certain full load conditions.
I'm sure the underlying design is solid with great potential but AMD has botched the Phenom release in a big way. I wouldn't touch this chip til we see how the B3 stepping performs in 2008. Anyone but the most blindly optimistic could have seen this coming for months. No company sits on a killer product and keeps the details to themselves as AMD have been doing recently. It really was a case of nothing to see here, move along...
prices won't rise. 99.9% of sales are to dell/hp and the bottom line is cpu price. if they can market a quad core with a £159 chip instead of a £165 chip, they'll do it. that will keep intel prices low, and amd. most buyers firstly don't need the power they get, and have no idea what the power of their computer really is anyway. money talks, always.
but again, i know someone has the msi platinum quad way crossfire board up at £135. somewhere else with stock sells it for £100. the intel chipset is incredibly expensive and their boards have always been somewhat more expensive.
you can get a quad core £145, + top end fully spec'd 4 way crossfire mobo for £100 + your choice of gfx cards all the way up to 4 if you want. one of the biggest differences is the same spec intel board would be £130-170 at the moment.
i think [h] showed one higher res gaming and the 2.4-3Ghz phenom, and the fastest intel cpu show within basically 1% of each other. quad core is and will be overkill for gaming for a long time yet. so on the scale of getting on quad cores for the cheapest you can, amd win and give you a system indistinguishable in gaming to a £600 top end penryn. but more to the point, the £165 q6600 wouldn't show a difference either, £20 there, £50 cheaper for a top end mobo with the ability to go quad crossfire in the future for that price is pretty damn impressive.
i mean, 9500 for £145, + a dual crossfire board high spec for £70, + a single 3850 512mb for £120. then add on another card for another £120. have 4x 3850 512mb for maybe unbeatably gfx performance(is triple sli up and running yet?). their range of products can go from cheaper, to fairly expensive with more gfx power maybe than nvidia can put together at the moment(not for long tbh). its not bad,
if they only reviewed high res games in a review almost any cpu over £60 from the last 2 years would give the same performance tbh, which makes intel and amd quads a complete waste.
thats pretty much what i said, 2.6Ghz, but they got into windows at 3Ghz would suggest 2.6Ghz stable but got to windows at 3Ghz. frankly, [h] seemed to have a fair few more cpu's available to them than anandtech(getting the impression since they've gone all adverts all the time they are losing respect from a lot of companies who might not pay them for avertising), and they said they think you can get 3Ghz quite easily with a decent 790 board, would suggest across a few cpus that was fine, and they normally talk about air overclocks so more clocking with less heat from better cooling, maybe?
like i said, i run my q6600 at 3.8Ghz mostly, because i have been doing a bit of encoding this month aswell as a lot of games that are doing better on dual core fast than quad core slow. but tbh, crysis felt the same at 3.8Ghz as at 2.8Ghz, so did cod4, and everything else i tried. my encode certainly went a bit faster as most i did using all 4 cores at around 80% full load, but it still, on a dvd encode to xvid, was only 20mins a pass. 25 or 30mins at a ghz less wouldn't have made a real life difference to me at all.
a thought occured to me, it would seem they are stock piling b3 steppings so they have numbers for release in q1 across the range of speeds. considering the black edition , well, only enthusiasts will buy it, in small numbers, would be freaking great if they let them out as b3 stepping. its not like dell need chips that will do good clocks, but it would go down great with the enthusiast community. hears praying.........
The first stepping is just about getting to market, in the next two months the real numbers will start coming when they ramp up speed and production of b3. The expectation is increased speed at slightly lower volts, a stock 3GHz part and a Black Edition.
It's worth noting that the A64 clock for clock has to run ~700MHz faster to compete with the Phenom so once we start seeing higher clocked parts we'll see some more serious bench numbers.
You have to admit the AM2 platform does look good, loads of future proofing and features that Intel can't match. Sure Intel has the absolute lead when it comes to benchmarks but in the real world most of just simply don't need that nor the expense.
From the numbers I have scene I have the following opinions.
1. Anyone building a new rig from scratch is more likely to go down the Intel path.
2. Virtually no one wil ditch a C2D or C2Q for the Phenom based on the benchmarks.
3. Phenom is only likely to appeal to people who currently have the AM2 platform.
My guess is that AMD simply didn't have the money anymore to come up with a competitive design. They needed to come out with 'something' but that's just to keep the company afloat.
Intel on the otherhand were getting beaten by a little company in performance terms, and sick of playing the inefficient company, pulled out all the stops and developed a really damn good product (c2d/q). AMD has to stick with SOI for the moment because they can't afford to change, where as Intel has amassed a lot of capital to be able to change that.
Hopefully the next product will be better with more money thrown at it. Main problem is, AMD tried to get too big, too quick and shot themselves in the foot.
Matthew
