Blame Crysis, im looking to go to 4GBs of memory (PC2-6400), but im not sure what to do, which is best etc.
Do i go for 4 sticks of 1GB or 2 sticks of 2GB ? Does it even matter ? Can my motherboard (MSI K9N Neo) handle it (someone said i would have to check its compatibility with 4GB, which the manual says it can take) ? Which brand is worth going for ?
What stands out to me is this -
http://www.overclockers.co.uk/showproduct.php?prodid=MY-086-OC&groupid=701&catid=8&subcat=813
But also someone recommended me this (if i buy 2 of course) -
http://www.overclockers.co.uk/showproduct.php?prodid=MY-066-GL&groupid=701&catid=8&subcat=813
What would you recommend ?
This if from the MSI website -
"Main Memory
• Supports Dual DDR II 533/667/800
- 4 DDRII DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 4GB."
I see that on the sticks ive chose, the Voltage is higher, does that mean i cant use them as my motherboard says 1.8v ?
Edit - I aint an Overclocker, if that means anything
Also, i see a lot about "Timings", are lower timings better ? And is it automatic on the motherboard ?
"Main Memory
