Cant get on MSN since this morning, doing my head in!
20 May 2006
I've always been able to get on msn, always!
And for some reason since this morning I can't get on anymore. I've tried everything I can think of to fix it.
I get this...
Any help at all would be awesome, i've been on google and loades of sites for hours trying to fix it...... yes hours! :O
I was actually on msn this morning, and after a reboot or somthing it just doesn't work...
Update:
Still having problems.
I've tried to fix it by doing all the recommended things such as-
But I can't seem to untick that box, every time I untick it and hit apply it just re-ticks it's self... So I can't do that section.
Moved onto the next section to try the SSL stuff.
I follow this, and get this
For all of them.
Spent about 5 hours trying to fix it now ^__^ it really doesn't want to work. :(
According to all the searches i've done 'Check for server certificate revocation' needs to be unchecked for messenger to work.
I can't uncheck it, cause it just checks it's self again. What's the point in that?!! ffs, why put an option in the damn list if you can't evan change it!
How do I get rid of internet explorer from vista? or is there a way to force this damn setting to stay changed!!!!
I barely use it but occasionally it has some sort of error similar to that, and its their side.
First google says it could be a server problem Click me!
I dont think ive ever had to do anything that "advanced" when msn stops working, its normally just a case of waiting for it to work again.
I know mate same here, a quick reboot usually fixes it.
I'm on an admin account.
dun, that's the site I used to get my info :p
yay x-mas smilys :D
Hmm. I wouldn't even consider it mate :D Although some people (you lol) take msn a lot more seriously than me. Glad you sorted it.
