medical (ish? question)
Status
Not open for further replies.
Caporegime
25 Nov 2004
On the road....
Tomorrow, 11:45Am I have to go into the NHS cesspit & have an operation.... (thats the North Staffordshire Hospital btw)
Now I'm doing this regardless, so its not really a "should I or should'nt I" question, I'd just like to know peoples views....
I'm off to work a 12 - 15 hour night shift now (and will get home between 2 & 5 AM) then, I'll be tidying up & finally going to bed at about 8AM & get up again about 10:30.
Should I have a general anesthetic after effectively what is an all-nighter? :eek::confused:
As I say, thats what I'm doing anyway - I'll check to see if the threads still alive when I get home from work - just wondered now that I've decided too is I really should at all!
Oh well, at least I know I'll get some shut eye tomorrow..... :eek::D
Cheers. :)
Just ring up and ask a nurse or someone in the know.:)
Either way a General anesthetic doesn't count as sleeping, you come out of it feeling so drained and tired IME :p
I woke up, Saw double vision unless i shut one eye and about 10 minutes later i slept for what was probably 12 hours :D
If you're only booked in for a daycase, they might be eager to ship you out fairly soon after the op but there's not much that they can do about it.
Just found this: http://www.asaabstracts.com/strands...57C9EAEB09F9B03?year=2006&index=5&absnum=1309
It relates to Sleep Apnea specifically relating to obese patients (the BMI was 51.8 ± 6.7).
The relevant parts are:
"In humans, however, the effect of sleep deprivation on anesthetic action is unclear."
"These data suggest that OSA with associated sleep deprivation does not meaningfully alter anesthetic depth as measured by BIS in humans. This finding differs from animal data demonstrating that sleep deprivation enhances anesthetic potency (1). One possible reason for this discrepancy may be that the degree of sleep deprivation in these patients was insufficiently severe to affect anesthetic potency."
I would say that because there hasn't been so much research into the subject, it won't be an issue.
Status
