Turbo owners...
13 Jan 2004
Would you say it is normal for a turbo'd petrol engine to raise the revs(on its own) upon a gear change before lowering to where it should be with a recirculating dump valve?
Might sound a silly question to some of you but I'm getting mixed answers :confused:
Yes, cos there will still be some boost in the system when you drop the clutch (esp if you still have your foot on the accelerator). The boost may well be enough to raise the revs a touch when the clutch is in.
Lets get the facts straight: It revs up when you press the clutch? Or some time after?
If the turbo is boosting around 3k rpm and then I change gear, as soon as my foot hits the clutch (my other foot is not on the accelerator) the revs will rise usually around 500rpm.
If it helps I drive a mk4 golf 1.8T
EDIT: the main reason I ask is that I have just had a clutch pedal replaced and the master cylinder along with a 80k service(sparks etc) and since then it has started doing this.
Erm dont think so mate.
Doesn't sound right to me tbh, sticky throttle cable?
Can't say that my 1.8T does the same.
And it's not down to there being boost left in the system, because once your foot comes off the throttle the throttlebody is closed. Even if there is still pressure there, it won't get past the throttle body.
Some ECU's do hold the rev's for a while after letting of the throttle though, as a feature to smooth any abrupt throttle movements and make for a more comfortable ride. It also saves on engine mounts. It could be that your ECU does this?
Definitely shouldn't be doing that. You want the rpms to fall, not rise.... so that you can drop into the next gear easily and quickly.
Possibly some sort of vacuum problem? I'm not sure you would notice something like that above 3000rpm though.
beats me
I only really know old engines. But if there is a leak on the inlet mannifold the car will tend to rev on when you take your foot off the accelerator because the engine is still able to suck in additional air as if the throttle is slightly open.
Like gurusan says id check for a vacuum leak.
Probably because the bite point is higher on the clutch pedal, and there is now less time between you letting go of the throttle and releasing the clutch.
I agree, sounds by far the most likely cause if any clutch components have just been replaced.
As said some cars (notably later Fords) do have this (hugely irritating) feature built in.
