//EDIT//
I'm very sorry, this should have been in General Hardware, I didn't realize i was in Graphic Cards.
Heya,
I'm looking to build my 1st proper gaming system, I've built small gaming systems and work systems in the past but I can finally afford to splash out and get a decent dream gaming PC.
I'll show the basket down below, but I would like to know...
Have I made good choices? Any problems with some of my selections?
Any better alternatives?
Is it all compatible with each other?
Will everything fit? (Cooler on MOBO)
Bar a OS, keyboard and mouse is everything that I need to setup this system, up and running, there? (Wires/cables etc)
I'm going to be installing Vista 32Bit, should I install just 2 gigs of ram? or keep the 4?
Is SLI worth it? (Never seen a SLI system)
Will also be looking to overclock after a months time of purchase, let everything settle in and warm up. Good system to OC? I'm going to need advice on that as well but I'll post that in the OC forum.
Thank you.
Heya,
Thank you.
