Dont they have a 14 day policy?
I didnt purchase the apple care...does that matter?
Also is it just a matter of giving them a call telling them ive got a stuck pixel and then return it too them?
Normally you can only return an item if it was bought with a standard configuration. Any upgrades normally mean you can't return it. Although you have said it was standard. Best give them a ring and see what they say.
Oh and of course pictures are required
BeatMaster![]()
hmm...i bought a Mini dvi - Dvi connector with it![]()
Ask them when you phone them if you can return it, pretty sure you can.
What would you plan on using the MacBook Pro for? If everyday use then the MacBook will suffice.
Go for it if you need the performance boost.
why's that? when mine arrives my plan was to jam it straight into my 22" samsung monitor via the mini DVI-DVI adaptor i bought??Well after using the macbook today and likeing it very much but id love to connect it up to my 30'' display which is not possible with the macbook.
