HI m8
I've found the same, maybe the CSL has far quicker traction control software?
Doubt it, mine doesn't fishtail up roads with DSC engaged either. Seems to catch most things on the road.
HI m8
)..... from what gibbo has said, the fact that the rear end was all over the place in a forty grand car with all manner of drivers aids just smells a bit fishy to me.
I hate it. I got in a car with driver aid and didn't realise it had it so I was push pushing the car trying to make it skid a bit and all it did was force the car on in a bundle of understeer. Then when I finally did get the back end out the nanny practically killed the car while I was compensating and I had to fight it back into my lane while it decided to try and control the car halfway through my maneouver. Then later on I nailed the brakes, felt a wheel lock so let off the brake a bit, the wheel came back in check and then the ABS practically let the brakes off on me.So, what's all this DSC/Traction Control you BMW lot keep talking about, then??
I'm not keen on these driver aids, not because they don't do a good job, or because they ruin the ride or whatever, but because you get used to them being there. Then, when you change car you forget that you haven't got them.
It's got that 4wd stuff so is of course infallible
Im astonished you needed to ask...Please tell me you are taking the mick
At the end of the day DSC can only get you out of trouble to a certain point. As soon as you've breached that point there's nothing it can do to save you. If you're not skilled enough to save it yourself then you're in a whole world of trouble basically.
If I didn't know any better, I'd almost interpret that as a statement of "my driving was fine, it's the fault of the car".
If you have that attitude, then I'd suggest that you sell your M3 now BEFORE the accident, which after all may injur others besides yourself.
Believe me, the safety of other people and myself is at the top of my priorities![]()
Cool, when is your skidpan/performance driving course booked for?
