- 3 Nov 2004
- UK
are they easy to instal?
Also, did you get higher overclocks with it compared to stock?
if you put that pc together in your sig then its hardly going to be any sort of challenge to fit a aftermarket cooler to a gfx card.![]()
@ fornowagain
that looks nice, how loud is that though? 2 fans on one cooler.
Same settings as OP. 44C Load. (22C Ambient)
Havent found the max overclock yet, but
760/1890/2160
SM 2.0 Score 6713
SM 3.0 Score 6331
CPU Score 5990
Surprisingly not at all, can't hear it compared to the case fan.
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=134
http://www.overclockercafe.com/Reviews/cooling/Tt_DuOrb/index.html
SM 2.0 Score 6713
SM 3.0 Score 6331
CPU Score 5990
It can, received next day. Can't say where sorry.Its like this cooler can't be bought in the UK :S
Part number is 'CL-G0102'
Woot it arrived got the old HS off, and am now putting the RAM sinks on.
Quick question I have some spare zalman heatsink things
http://www.overclockers.co.uk/showproduct.php?prodid=HS-014-ZA
Can I put these on the voltage regulators?
guess so but i never bothered cause they were bearly covered in the first place.
