Gigabyte GA-P35C-DS3R - Vista 64 issues
7 Feb 2004
I have just installed Vista 64 and I can not get the audio to work on the comptuer now. I had problems before with this but can not remember how i solved it.
Can anyone assist me please?
Thanks
Seemed to install after I took disk out and in. Although it doesnt appear to be the same setup for Vista 64. Less option to choose.
On Xp it shows a little picture of the ports at the back and you can choose the port for what option you want. But on Vista you have to guess which port does what.
The sound ports?? On mine they installed exactly how they said they would in the manual , you tried uninstalling etc...............
