First post
I just got permission to upgrade to a couple of 2007WPs (which I just got my shipping email for - thanks OCuk) on condition that I do this project too!
So now I need a 24" (roughly) monitor and it's for movies only.
Yes, it's going to be for watching TV in the bath. I was told to do it so don't moan at me.
Now, I'll grant you that a bathroom install isn't for everyone - but I don't really think that bit matters - hopefully these questions are interesting to anyone who wants an LCD for a MythTV or MediaCentre TV
It will be RCD protected and in a big toughened-glass-enclosed (and vented) alcove which is in another room essentially. So don't worry about electrics, overheating or humidity - I've got that covered
It's going to be connected to a HTPC, not a tuner/dvd player so VGA or DVI.
Viewing will be at ~2m and it is going to be wall mounted on a tilt mechanism so it will be pretty much head on (and I can guarantee there won't be too much movement from the sweet spot ) This makes me think that TN may be OK.
So, options:
* TN based : Dell E248WFP (gamut benefit) or Samsung SM245B
* PVA based : Dell 2407WFP-HC or Hyundai W240D-PVA (glossy ... mmmm)
I suppose I'm wondering if I'm letting myself in for a problem using a TN screen as a TV - ie do they provide an acceptable video image?
If consensus is that they're OK then "problem solved" (well, easier anyhow!)
If TN isn't the way to go then I guess the Dell 2407 WFP and WFP-HC is the next obvious choice (better viewing angles) but extra £££s too.
I guess the 2407 WFP is a no-risk answer but the additional colour of the -HC would probably be nice for TV/film.
However (!) it has potential ghosting issues : do these ever show up in video or are they more specific to games?
Finally the Hanns-G HG281DP may be in the running 'cos it's cheap - but only if it fits and it's good for TV. The alcove is 680mm wide.
So, thoughts would be much appreciated
 ) This makes me think that TN may be OK.So, options:
