HD and a HD Ready TV
One and the same..
Ah that makes sense then
Were they right about the 1080i and p thing? Would there be a difference @ 32"?
@32" you would do well to notice a difference at a normal viewing distance. The general opinion is that Full HD (1080p) begins to be more noticeable at 42"+
The best way to decide is to try to get the shop to set up the 2 tv's side by side, you can then see if any difference is worth the extra £££
