- 17 Sep 2006
- Gloucestershire
Ok so I decided to update my bios to 2302 (I think!) using the asus update sevice from within windows (which I now realise was a BIG mistake!)
I selected the newer bios file, but it said it failed to flash. I tried to reload the update software, but it said no bios detected, at which point I was feakin worried!!
Stupidly I tried to restart the comp to see if there was no a problem with the bios, and there is!
I get no post, no beeps, the comp just turns on and nothing happens. (Please note that all hardware is fine, so its not a problem with that).
In currently writing this on a mates comp as ive removed the battery from the mobo, and moved the jumpers across to reset the bios.
Is this a serious problem? Im hoping that after a couple of hours the PC will boot, but if not, what am I to do?!
All help is much appreciated!
