As part of my ongoing revamp of our Watercooling Section I have introduced the Brand New Alphacool Kits to our range.
You can have your choice of Dual or Triple radiators with either Eheim or Laing manufactured pumps/reservoir combos all with a NexXxos XP Nickel Plated CPU Block, The copper surface of which is glass-beaded in order to increase the cooling surface.
A selection of Accessories and Blocks will follow shortly for those of you who just have to watercool everything
I have also introduced the Thermaltake Big Water 760i for those of you who still don't fancy building your own WC rig.
This really is a Plug N Play watercooling kit, with quick-connect, non-spill valves that shut off water flow immediately when dismantling to prevent water leakage.
