- 19 Oct 2002
- Manchester
If the turbo is boosting around 3k rpm and then I change gear, as soon as my foot hits the clutch (my other foot is not on the accelerator) the revs will rise usually around 500rpm.
DBW if I remember correctly? Engine code - ARZ(late 2000)
No, it shouldn't do that then, but a late 2000 will be DBW so could very well be the throttle pos sensor or throttle body sensor sticking.
Did the battery get disconnected when the work was done? All DBW vag cars require the throttle body to be reset whenever the battery is disconnected.
Know anyone with a VAG-com as the chances are you'll be throwing up some fault codes.
Also ask on any of these golf forums to see if anyones got any similar experiences with that particular engine code (is pretty common for certain engine codes to have their own particular issues)
www.uk-mkivs.net
www.edition38.com
www.clubgti.com
www.vwvortex.com
