Tripod needed - Bulletproof, yet to a budget.
1 Sep 2005
Scottish Highlands
Im going to do my own research, but I wondered if anyone had any experience or advice regarding tripods with the following specs;
Bullet proof (Or rather, studentproof which is probably worse).
Weight doesn't matter
Maximum budget about £100-£150 (+another £100 for the head)
Must be simple to use (Again student proof)
For the head, its mainly going to be used for DV-cameras, but occasionally also for stills cameras, so im thinking a 3 way head of some sort, but again it needs to be very very durable. If something doesn't work or want to go in a certain direction, students have a tendancy of making it go, despite the cracking sound suggesting otherwise. :(
A friend recently bought the Velbon DV6000, under £90 from the usual highstreet camera retailer... Has really impressed me with its sturdiness/ease of use.
He has it setup so that everything is moveable, yet tight enough that it doesnt 'self adjust'.. And thats using some large lenses on his 400d. I know the tripod is really designed for DV cameras, but it works superbly with his camera.
Sam C
With students you want a tripod where nothing can be removed or unscrewed.
And that might be a tall order. With the students I've seen, I would be tempted to expoxy a screw thread into a block of concrete...
Andrew
I use a Monfrotto 190PROB with a 488RC2 Ball Head. I can vouch for the tripod itself, it's fantastic but heads are more a personal choice. A lot of landscape guys prefer a 3-way head for easy panoramas. The 488RC2 has the best of both worlds with a seperate pan control.
Manfrotto 055XPRO. Got one a while back and it meets all your criteria. Not the cheapest, but it's really well built.
What DV cameras is it going to hold? I used to work for Vinten and they make unbelievably sturdy tripods and heads, like seriously well built. Check them out, although I am not sure they do anything in your price range.
Yep I would go for the 055Pro, within budget and bulletproof (it has to be with me, I really should look after it more :o:p). The 804RC2 Head goes well with it too. Overall quite heavy, but it's still standing after various 'incidents' while carrying and cycling with it. :D
Slik Pro 700 DX.
Maximum Operating Height: 1,900 mm
Minimum Operating Height: 620 mm
Maximum Center Column Extension: 380 mm
Folded Length: 760 mm
Weight: 3,200 grams
Number of Leg Sections: 3
Leg Lock Type: Speed Release Lock
Maximum Load: 6,800 grams
Built like a brick ***house and under £100
Not light, but massivly impressive for the money.
Thanks everyone for the suggestions.
Andrew
Hehe, yeah that isn't too bad an idea.:D
The Manfrotto 055XPRO is already on my potentials list. :)
Manfrotto 190xprob and your head of choice to suit.
Ive got a Manfrotto 190xprob for my own persoanl use, and its not a simple or strong as id like tbh. If I was a student im sure I could break a 190xprob with a bit of effort.
Thanks for the suggestion. The cameras are normally Canon DM-XM2 or Canon MV890. The stills cameras are Canon 350D, but primeraly the tripods will be for DV camera use.
Slik Pro 700 DX.
Weight: 3,200 grams
Someone else suggested this one over at TP and its a tthe top of my potentials list. Looks very good for the price. :)
