IP35-Pro - 4x1gig sticks :(
18 Oct 2002
Hi All,
My IP35-pro and Quad turned up this week. I was running 2x1gig OCZ platinum and 2x1gig OCZ gold in the old system, which worked.
When setting up the new system, i noticed that only 3 gig was showing up (In BIOS, not in windows). I put it down to the ram being mismatched and bought another pair of Platinum OCZ 1gig sticks (dual kit) so that I had 4 of the same. Unfortunately, it is still the same :(
I have tried the latest official BIOS and the latest Beta. Upped the MCH, manually set the timings and still nothing.
Anyone have any ideas? If i cant get this working, some recomendations on what 4gig setup would work would be greatly received.
Thanks!
Edit: Just to mention, all memory sticks work fine as pairs, in any slot. They also work fine as single, in any slot. It appears this is some sort of issue between the Mobo and 4x1gig configuration.
18 Oct 2002
Welsh Wales
OP
18 Oct 2002
Thanks for the confirmation, it was actually your posts that pointed me in their direction in the first place :)
Guess ill bite the bullet. Will either sell the OCZ or stick them in my fileserver and it can be my VMware lab mule too.
Cheers!
18 Oct 2002
Welsh Wales
I've stuck to version 11 (shipped one). It's been solid with my overclocks. Unless I have to change it, I'll stick with this one. I have no floppy drive, and although I always flashed my old Asus board from Windows, I don't want to risk knacking this one up. I have a pen drive if needs be.
OP
18 Oct 2002
odd one, did you try the different slots with 1 stick in at a time?
any possibility of a duff slot?
Edit re-read and noticed yes you had
bit of an odd one then
Yeah, pretty odd. Several years back this sort of issue was quite commonplace, havent seen anything like it for a long time. Motherboards used to be fussy buggers!
No matter, the quad goes into windows at 3ghz @ stock voltage. Havent had time to fully hammer it yet though ;)
22 Apr 2006
Port Talbot
Also running 4 1gb sticks of Geil at DDR 912 voltage 2.05V on the Abit ip-35pro Cpu is set at 1.24V (3.4GHz) but is measuring at 1.20
The board itself though seems screwy on voltages
OP
18 Oct 2002
Did 5 hours of Prime95 on 4 cores today at 3ghz, stock volts. Think ill just leave it at that. Nice combination of power and temp :)
OP
18 Oct 2002
The 4x1gig of Geil arrived today. Same god damned problem :(
God only knows what the issue is. Each memory slot works fine on its own, or in pairs, but it just will not function with all 4 at once, even though several others use this exact combo :(
Time to downgrade the BIOS i think.
sid
sid
9 Feb 2003
London
Have you put 2.1V through it first?
Theres known bugs with this board and 4 sticks
my ocz 2gb xtc stuff wouldn't post at all with 1.8v
sid
OP
18 Oct 2002
Yup 2.1.
I fixed the 4 gig thing by downgrading to bios 11. Now the BIOS and Windows see all memory.
What I have done in the process is find a new bug.
I go to put my original overclock to 3ghz in and all looks fine. When the device posts it shows 9.2ghz and DDR at 2500mhz lol.
Anyway, it goes into windows fine, but has discarded my overclock and is sat at 2.4 again :mad:
God.
Gotta go out now. Any ideas would be appreciated. Ill be googling it also when i get back.
Ta.
