assuming you can still type when the time comes![]()
quite honestly he's not doing too well at the moment so any finger removal will make things much worse
is it possible to reduce the temp down far enough to create a solid block of nitrogen, or oxygen?
Theoretically, yes. But nobody's managed to achieve absolute zero at this point and it's doubtful they will for a good, long while (yes, they've come within 0.001oC or whatever, but hey).
And CO2 sublimes from a solid - it does not evaporate. Nitrogen evaporates, but that's because it turns from a liquid to a gas.
LN2-based cooling is only really advisable for suicide runs as it is not what I would describe as being remotely practical. You'd be safer (and probably cheaper in the long run) buying a Prommie or Vapo.
Is liquid oxygen colder than nitrogen?
