I'm wiring in a heated screen to the VX but I'm not sure how thick the cable needs to be to carry 35 amps...
The screen comes with 2 wires attached which are pretty small, maybe 2mm diameter cable, these then need to be wired to a relay and them onto the battery. I believe the screen draws about 30-35amps for a period of 15 minutes. I have some wire which is roughly the same size as the wire attached to the screen, is this cable sufficient for 35 amps?
