i bet you cant work this one out! ruvatuner sli problem
1 Dec 2006
Amsterdam, NL
as you can see in the printscr its not doing anything for the second gpu, declocking it infact! now, this happens with every version of rivatuner above 2.2. i would like to use the latest for the sahder clock obviously, but i have no idea why its being in a pain. in the 2.2 version i simply click 'Test' and it applies to both GPU's and alls dandy.
any ideas?
agnes
p.s. sorry for the high res, i run at 2048x1536 hehe
If you have SLI enabled in the NV control panel you shouldn't even be able to select the 2nd GPU in Riva Tuner. RT sees an SLI setup as a single card so only has one graphics card available in the drop down box and thus the overclock you apply to one applies to the other. I don't understand how you have access to two clock frequency adjustment windows at all.
Try disabling SLI in the drivers then enable it again.
done, and its always worked so that i can see both cards, on any version sli or not
ags
Yeah I have the same overclocking problem with the 169.09 drivers, In that it only overclocks the first card.
169.01 works fine though.
Do you think having cards from different vendors(different bios) would affect this?
nope, i got 2 BFG gtx's with the DD water blocks on meaning they are exactly the same. yet i get it. maybe its a beta driver issue...
ags
