B&Q and Homebase sell them in various sizes.Where can you buy these cable ties?
How do we qualify for access to that [MM]? Postcount?
I've ordered an S1 and a sharkoon 120mm fan to fit on it, can anyone who has stuck one on NOT used velcro on it and if not does it vibrate much? I really don't want to go from this annoying rattle to another annoying rattle![]()
A cowboys affixing tool.
the accerlo s1 wont allow a sli configuration will it?
ive just gone and ordered 2, like a MUG
i ordered 2 akasa amber fanswow i shouldve really looked into this before spending £70 lol
so your sure the sli bridge will fit through the coolers? thats the main concern.
just at a glance, the 2 slots on my p5ne look about 10 cm apart, is that far apart enough do you think?
Just fitted my S1 onto my new 8800GT and I'm stunned by how much it cools this card passively. The card idles at about 37 degrees and on full load goes up to at max 50 degrees!
Thats also with a PNY card clocked at 700/1750/2000![]()
is it easy to fit? i have never changed a gfx cooler. do you need to add thermal paste to the core?
