New Sapphire HD3850 256mb
I've got 2 akasa amber 120s aimed at the card :o idling at 39c now.
Took me a while to figure out the unknown pci device in device manger was the HD audio drivers that were missing.
Sounds like a nice card - If the 3850's are the same layout wise as the 2900 then one of the thermalright HR-03's would be brilliant although obviously it is a lot larger than the stock single slot cooler :p
Are these settings OK? Sorry for the noobish questions but I've never bothered with decent gfx cards before.
I can't equate these numbers to the OP of this thread. same card BTW.
All at stock.
Anyone getting BSODs since installing this card? I've had 3 today.
Page fault in non paged area......win32k.sys
Googling around suggests driver issues, albeit same fault with other cards.
no bsod's, but it did freeze on me running the high settings @ 1024 in benchmark mode
managed a run at 1024 with med, and scored 59/60/60/60 average with std clocks, and 60/66/66/66 with cards at 759/954
system is a Shuttle SD37p2v1 - [email protected] - 2 gig xms2 epp - 2 x Sapphire HD3850's - XP Pro
I did an ununstall of drivers, ran driver cleaner then re-installed. Been playing crysis demo, then it BSOD when I clicked on quit, same error.
It did it also during simcity societies. Probably a driver update will help when released.
Blimey, must get a bit warm in a shuttle with 2 of 'em :)
I haven't really bothered with cooling mine down, though I dont really game on the pc its my HTPC, I did however open it up yesterday (just after testing UT3) to mess about with the CPU cooler and my god the card was so hot it nearly burnt my fingers!
I really need a decent aftermarket cooler I think, any ideas which fit? I'm even considering going watercooling just after xmas.
