- 10 Oct 2007
- in the arse of england.
if so, can you run some bench marks for me and post them here as i want to compare performance to my current CPU to see if its worth me up grading. thanks.
the x1950pro won't be any faster than the 1900xt.. well, nothing noticeable.
I went from a 2.4 opty to a 3.2 e2180, and the difference is incredible.. Obviously, you're starting with a higher clocked opty, but for the price of the upgrade, it's well worth it.
I have an E2160 an an X1950 Pro, around 5k in 3dmark06, 200fps on CSS on ultra high, CoD4 on Ultra High, Crysis on medium etc.
is that all? (is that stock settings or overclocked?)
seems a little low to me, being as my sig gts just under 4.5K
im hopeing to be getting an E2180 this week but overclocking it hopefully to 3.2
i was going to upgrade too but i dont think its worth it tbh unless you get it running at 3.5ghz as i got a mate to run some cs:s timdemo's and his results were more or less identicle to mine and he has a e6850 @ stock.
heres my 3dmark06 too http://service.futuremark.com/compare?3dm06=3547307
I'll be building a rig consisting of the following, E2160, P5E, Ocz 6400 Ram, and a x1950 xtx running in crossfire.
I'll bench it in single mode and then in crossfire and let you know what my findings are, I'll probably use 3dmark06,05 and aquamark.
The E2160 will be overclocked to around 3ghz if it goes that far.
a super pi 1M result and some avi to DVD encoding results would be useful too if you dont mind?![]()
That's at 2.8ghz and the 1950 Pro is the bottleneck.is that all? (is that stock settings or overclocked?)
seems a little low to me, being as my sig gets just under 4.5K
I built my rig up last night quickly,
E2160 @ 3150mhz stock cooler @1.295v
Asus P5E
X1950 Xtx's in Crossfire
OCZ 6400C4 xtc Ram
In 3dmark06 i was getting about 7000marks in single mode,
Cards set at overdrive max so 695/1098
In Crossfire about 12000marks.
Further tweaking will be done but so far the rig is pretty good I'd say.
I need to tweak/configure the processer and the memory properly.
And get to grips with the best drivers for my X1950 xtx's as I'm using Cat 7.11 and i think the best is probably 7.8 or 7.9 as my old rig prefered these over the newer driver.
