May I ask, which street fighter game is that? what console?
Also what's so hard about blocking the chun li kicks, do you have to actually block each kick invidually? Is he using some sort of special block or something?
The end finish is definitely awesome though.
He had to manually block every single incoming hit (mis-timing a single one would result in him losing), which amounted to 15 parrys and then one in mid-air before unleashing his own finishing move...
I actually found that Ikaruga one to be the most impressive. As you see in the description there are actually two damage types and he's flying both ships around constantly switching between them at the end so he doesn't get killed.
