How does one find the EXIF?
Caporegime
25 Jul 2003
FR+UK
Sorry if I'm being a noob, but how do I view a photo's Exif data? Do I need a particular program or is it viewable in Photoshop?
You should be able to right click on the photo file itself, then click on properties, then click on summary, you may have to then click on the advanced tab.
Err not sure if Photoshop lets you view the exif data, it might, but I don't use it to do so.
Adobe Bridge, or Lightroom will let you. Also I can see it on the properties If i right click in Windows select Properties -> Summary -> Advanced. I'm not sure if that is something I've added in though?
He he, someone is a bit more awake than me :)
