- 18 Oct 2002
- Nr Colchester, Essex
You are lucky then, cause this is blooming annoying!!!!
Seriously - if you're looking for an excuse not to buy it then that's fine.
Here you go, a lot more vivid to the naked eye, actually shows up better I grey I think
http://www.doufos.co.uk/upload/line.jpg
http://www.doufos.co.uk/upload/line2.jpg
That looks very strange indeed.
Ive only ever seen anything like that when there is a problem with a graphics cards.
Never seen a faulty monitor with a continuous line like that before.![]()
By the way, anyone managed to register their warranty yet?
Will this work with xbox 360 straight out of the box? Or do i need this VGA adaptor cable?
registered when bought, it was the URL on the plastic screen cover
Thats what i thought, though i was just confused about where the two audio plugs (red and white) go? As from all the pics posted I cant see where they plug in.
The cable comes with an adapter to plug into the 3.5mm jack iirc, also has Optical out for digital.![]()
