My mobo died today, so I'm either going to RMA it, or take the opportunity to upgrade. Specs-
DFI LanParty UT NF4 Ultra-D
AMD Athlon 64 3700+ San Diego
G.Skill 2GB DDR HZ PC4000
Leadtek GeForce 7600 GS SILENT
Creative Sound Blaster Audigy 2 Platinum eX
Maxtor DiamondMax Plus 10 NCQ 250GB 6V250F0 SATA2
Sony DWG120A 16x16 DVD±RW Dual Layer ReWriter
Hiper HPU-4B580 Type R 580W
Akasa AK FC-03 Fan Controller Pro
Do you think it's worth taking the opportunity getting a new AM2 mobo, also upgrade to a 2 core AMD CPU. Of course I was also thinking if I'm doing that it might make sense to upgrade the RAM to DDR2.
As you can see the upgrade option starts to get a little pricey. Is it worth it do you think? I was looking at this bundle - http://www.overclockers.co.uk/showproduct.php?prodid=BU-068-OK&groupid=701&catid=339&subcat=
I'm having trouble justifying spending money on new mobo/cpu/ram and need some persuasion/discouragement.
Thanks
Thanks
