Model shoot advice - lighting
Caporegime
1 Nov 2003
Lisbon, Portugal
Hello all,
My GF has asked me to do a shoot on her 16 year old sister for her birthday (will be turning 17)
Now, we are going to rent a studio for an afternoon which I presume will provide softboxes and other lights.
But I've never worked properly with softboxes and done much model photography before. Was wondering if anyone can offer any friendly advice? :)
Not sure what to ask, I'll be using my 350D with: 17-40L, Nifty Fifty, 85mm 1.8
If anyone can post advice on how to cast the lighting against the subject that'll be great, they are a Mauritian family so she hasn't got black skin but it's not white either, sort of a tanned inbetween :)
Any help is greatly appreciated.
Many Thanks :)
I'd check with the studio exactly what is provided, whether you'd need supply triggers, whether their triggers are compatible with your camera. All that assumes they provide the lights...
Lighting wise, make one prominent (ie closest) then use the others to fill the shadows so they aren't harsh but not so much that everything looks flat with no depth.
Im going to assume the studio will have the following things, as you will need them.
Light meter
Flash sync lead/adapter
Stands.
Studio Flashes
Softbox
Reflector
Backgrounds.
Most will have all, i would hope so considering your renting it out, but you need to check
First thing to consider is the background, if its white it will be a different set up to if its black, or a coloured/picture, or even a wall, il try to give you an idea on how to do all of them. Basically you have to over expose a white background, underexpose a black and in between for colour. (this all really depends on what type of studio it is mind)
Firstly position your model. My advice here is about a metre or more away from the background (assuming its a paper one) as it will lessen harsh shadows and give you room to fill light into the background.
Position model in the centre, you have to options now, 1 flash with a softbox on one side of her, and a reflector on the other or 1 flash with softbox above your own head and face centre on. (if your moving about a lot without a tripod then a reflector you move around is a better option)
Take the light meter and set it to what aperture you require, connect it via the sync lead to the flash and place infront of models face (assuming you know what a light meter does and how it works) flashes will go off, and light meter will give you the required shutter speed. Adjust the flash intensity untill you get a acceptable reading aof about 1/125s. Thats your model exposed correctly.
Next you must exposure your background.
White backgrounds require you to double the intensity of the model flash so that when you use your camera set to expose the model perfectly (based on you initial light metering) you get an over exposed background which is nice and white.
Do this by setting up to flashes either side behind the model pointing at the background with no soft boxes, remove the model from the scene and sync one flash, set the other flashes to go off via remote. The light reading taken from the furthest point must be 2 stop above the model reading, so if your model exposed at 1/125 you need the background to expose at 1/500
Colour background need to be exposed at the same or 1 stop above
Black backgrounds need to be exposed 2 stop below, say 1/40 or below. (you can even use lighting below the models back point at her for artistic effect)
If the studio has wall spaces and seats for fancy work then you will require either 2 softboxes or 1 and a reflector, apply the same principle of taking a light reading while synced to the light meter.
If you can use a light meter, set it to f8 and then adjust the flashes untill it gives you a reading of above 1/60 at a minimum. (as she will be so close to the backgrounds the should also expose fine)
Do not use the flash on the camera it will cause shadows on the face.
Hope that helps, ask any question you may have.
Fantastic ChroniC :)
Will post more questions later, when I've got a little time on my hands, really appreciate you doing that though :)
EDIT: How rude of me, nearly forgot divine. - Thanks mate :)
Have you done this yet, I have recently done a photoshoot for 3 girls, with the same process. I will show you how i did it if i can get permission of them to let me post there faces over the net.
No I haven't, haven't had time yet.
You can always email me at [email protected] if they prefer not to have their faces shown on the net :)
Thanks pal :D
