- 21 Jan 2007
- GLENROTHES-FIFE
Well, I've been at this setup for a few days now and have finally managed to tame this 9500
MOFO64 presents the worlds first RETAIL oc'd B1 9500 to reach 3GHZ (not B1....B2 - typo at the time)
After many hours of trying lots of settings, MOFO is proud to announce that this phenom (and others aswell no doubt) can hit 3ghz (albeit very unstable).
Motherboard used MSi 790X.....CPU X4 9500 @ 2904mhz (cpuz verified).....RAM 4GB ADATA DDR2-800 @ 880mhz 5,5,5,15,24,2t
I use WPCREDIT to drop the NB mutli to x7 I managed to attain this OC.
Firstly due to this boards bios, I cannot access memory timings....only divider....however it detects my memory modules spd timings np.
There is also no NB multi access (dunno if there is supposed to be) so this is where WPCREDIT helps enormously.
1...I boot with a FSB of 215mhz, 1.560v vcore, 1.40v NB, HTx of 3.
2...Once on desktop open cpu and use mem tab to check NB speed.
3...open WPcredit and change NBx to 7 using 00011B, apply,close restart.
4...allow system to restart but do not enter bios.
5...once on desktop again open cpu and check NB multi & speed are properly applied, you'll see they are.
6...Now I use AOD to increase cpu fsb slowly. Do not increase anymore than 2mhz at a time as 30mhz-40mhz increases can cause lockups
, but seriously though, 27 seconds pi 1M??? Doesn't look great, tbh.
