30 Nov 2007 at 19:38 #1 Jamemoff Jamemoff Associate Joined 14 Nov 2007 Posts 180 Location Worcester Hi guys i finished building my first pc and now i am trying to overclock it can you guys take a look at this and tell me if its ok thanks
30 Nov 2007 at 19:55 #2 weescott weescott Soldato Joined 25 Feb 2004 Posts 9,393 Location Heckling for change Test it with Orthos/Prime95/F @H for 12hrs or so and see. You could probably tighten up the ram timings though. What ram do you have?
30 Nov 2007 at 19:57 #3 Pen66 Pen66 Associate Joined 1 Oct 2007 Posts 1,090 Multipier x8? Think you can change it to 10 if your motherboard lets you, should help a bit.
30 Nov 2007 at 19:59 #4 Jamemoff Jamemoff Associate OP Joined 14 Nov 2007 Posts 180 Location Worcester i got Gigabyte GA-P35C-DS3R and GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit how do i change the ram thing? Last edited: 30 Nov 2007
30 Nov 2007 at 20:47 #5 weescott weescott Soldato Joined 25 Feb 2004 Posts 9,393 Location Heckling for change Change the ram to run 4-4-4-12. Stock timings for your ram. There is an option in the bios to change it...somewhere. Are you using stock cooling BTW?
30 Nov 2007 at 22:04 #6 Jamemoff Jamemoff Associate OP Joined 14 Nov 2007 Posts 180 Location Worcester no i got a Freezer 7 Pro , i cant find were to change the ram timings Last edited: 30 Nov 2007
30 Nov 2007 at 23:56 #7 naudiz naudiz Associate Joined 24 Apr 2007 Posts 545 Location Rochford Hit ctrl and f1 I think it is??? in your bios screen, should unlock the timing options in the overclocking menu Naud
1 Dec 2007 at 00:06 #8 Countcussy Countcussy Associate Joined 10 Nov 2006 Posts 1,370 Pen66 said: Multipier x8? Think you can change it to 10 if your motherboard lets you, should help a bit. Click to expand... Surely this should be at 10 by default?
1 Dec 2007 at 00:12 #9 Jamemoff Jamemoff Associate OP Joined 14 Nov 2007 Posts 180 Location Worcester when i change it to x10 it wont boot
1 Dec 2007 at 11:12 #10 Jamemoff Jamemoff Associate OP Joined 14 Nov 2007 Posts 180 Location Worcester This better Guys? Last edited: 1 Dec 2007
1 Dec 2007 at 12:10 #11 CrabbyCliff CrabbyCliff Associate Joined 29 Nov 2007 Posts 123 your core speed has gone down to 2.1ghz ..... supost to be ?
1 Dec 2007 at 12:22 #12 Jamemoff Jamemoff Associate OP Joined 14 Nov 2007 Posts 180 Location Worcester no its at 3.5ghz
1 Dec 2007 at 12:27 #13 CrabbyCliff CrabbyCliff Associate Joined 29 Nov 2007 Posts 123 oh nice, what software did you use ?
1 Dec 2007 at 13:56 #14 Jamemoff Jamemoff Associate OP Joined 14 Nov 2007 Posts 180 Location Worcester i changed it in the bios
1 Dec 2007 at 14:00 #15 Stev Stev Associate Joined 10 Nov 2007 Posts 848 Location South coast whats your temps with freezer pro?
1 Dec 2007 at 14:08 #16 Jamemoff Jamemoff Associate OP Joined 14 Nov 2007 Posts 180 Location Worcester 32 Idle and about 50 load
1 Dec 2007 at 17:28 #17 LabR@t LabR@t Soldato Joined 30 Nov 2005 Posts 13,916 what volts did you use for that, ram only at 350mhz bit of a shame mine is at 3ghz ram running at 450mhz 5-5-5-12 geil LL stuff vcore up one notch from default
1 Dec 2007 at 17:45 #18 waso_dude waso_dude Soldato Joined 22 Oct 2006 Posts 5,913 Disable Speedstep and C1E Will remove the dropping multi, and that clock looks really really good.
1 Dec 2007 at 20:08 #19 Jamemoff Jamemoff Associate OP Joined 14 Nov 2007 Posts 180 Location Worcester where do i change that m8?
1 Dec 2007 at 20:43 #20 Duke Duke Man of Honour Joined 29 Jun 2003 Posts 34,679 Location Wiltshire It will be on one of the main BIOS menu screens Shouldn't be too hard to find.
