Beta patch 2 changelog for those who are interested.
Here are the changes between beta 1 and beta 2:
- filter settings are now saved to the .ini file.
- fixed UTUIComboBox's editbox and list getting out of sync (editbox text
could end up not matching the list's selected item)
- fixed changing gametype via combobox on server browser tab causing filter
settings to be clobbered
- changed default value for "Pure Server" and "Locked Server" filter options
to be more lenient (show more servers by default)
- Fixed ping values shown in scoreboard
- Don't show ping for bots
- Fixed Miplevel spam when applying patch to dedicated server build.
- Fixed dedicated server getting removed from the master server list if the
first player to join fails authentication.
- Bringing up the midgame menu now pauses demo playback.
- Players now stop moving if they fire the Redeemer altfire.
- Fixed joining a passworded server via the server history tab not prompting
for the password.
- Fixed viper and scorpion self destruct death strings.
- Fixed when the player tries to cancel a "Delete Demo" the demo still gets
deleted.
- Fixed HTTP redirection
- Fixed download cache clobbering files that had just been written in some
cases
- Increased default download cache size
- Fixed FOV option when patching old .ini's
- Fixed crash when exiting the editor.
- Smaller/simpler simple crosshair.
- Added the ability to delete saved messages
- Implemented DUEL match stat reporting for gamespy ladder.
- Fixed an exploit in CTF-OmicronDawn that allowed players to get outside the
world.
- Fix for hole in WAR-Islander where players could get stuck
- Fixed orb rebuilding not being played correctly on clients if the orb was
destroyed by an enemy player.
- Fixed flickering when downloading files.
- Don't reduce tickrate when travelling with no players - fixes server hanging
for long durations on EnvyEntry.
- Fixed custom characters not working correctly when playing back demos
- Added the ability to specify custom simple crosshair coordinates for
weapons, with new config properties bUseCustomCoordinates and
CustomCrosshairCoordinates.
To change the crosshair used for all weapons, add the
following lines to the [utweapon] section of the UTWeapon.ini file:
bUseCustomCoordinates=true
CustomCrosshairCoordinates=(U=276,V=84,UL=22,VL=25 )
where the customcrosshaircoordinates have U and V as the
offsets into the crosshair texture (UI_HUD.HUD.UTCrosshairs), and UL and VL
specify the size of the texture area to use.
To use a different crosshair for a specific weapon, simply add
those two lines to the appropriate weapon specific section in UTWeapon.ini.
From Epic
We believe this version to be a strong candidate to become the first official patch. We're already working on features (like web admin) for the second patch, but we believe this first patch contains enough important improvements to release as soon as possible.
Taken from
here
