- 2 Dec 2006
What waas the cost of the 8800GTX around 4months after release as ill be buying a 9800GTX around june which hopefuly will be 4 months after.
Enough about the prices of GT's, wonder what GTX cards will be worth ? there still over £300-ish now
If that is true then it pretty much leaves the rumour of an 8950gx2 in January dead in the water, would be pointless if a new gen is released 30 days later.
Depends on the cost and performance.
If the GX2 costs less than what 2 GT's cost, and is a single board card, and does not require SLI to work, and performs nearly twice as well as a GT, then it may be worthwhile.
Remember, the 9800GTX will likely be over £400.
Even if it doesn't require sli enabled motherboards to work (7950gx2 didn't either) you still have the profile thing which means not every game will work with it and some obviously will not show gains as large as people would expect. Id say most will hold out for the 9800gtx or gts depending, dual cards can be good but given the choice i think most will go for a single card.
Anyone know? Was it like 380 quid for a BFG OC or more?
What is "D9E"?
Screw the new GTS, I'm sticking with my GT until these beasts come out, and if it is february, all the better.
'9' Series 'E'nthusiast part.What is "D9E"?
At what cost though 500 big ones?
