Car Headlight Bulbs
24 Mar 2006
I really could do with some new headlight bulbs for my car. Dipped and full, as i would be able to see more if i taped a torch to the front bumper. Can anyone recommend any bulbs which are firstly legal, light up a large area well and are reliable.
Thanks
410 is an old tunsten type bulb with a round glass, you can get upgrades to halogen type.
H4 is halogen, straight glass with 3 lugs round the metal base.
You can upgrade to halogen from the 410 but there are few "brighter" types
If is it H4 then there are plenty options, anthing from Ring, Phillips or Osram will do, with Osram being the best choice.
If you have H1, H3, H4, H7 or H11 then definitly get the new Osram Night Breakers. Not cheap for halogens but from whats been said they are meant to be really really bright for a halogen.
A standard halogen bulb does on average 1500 lumens, the measurement of light, depending on the fitting used. Then you get the HID Xenons now which produce between 2800 and 3500 lumens depending on the temperature of the bulb. Lower the temperature the higher the lumens, most OEM use lower temperatures because of this. Though the temperature changes the colour of the light, lowest for a HID is a white, then it goes to a blue tint, then finally goes to a purple tint at high temperatures. If you were to get a HID I would suggest the lowest temperature, due to the higher lumens.
But lately design of halogens have been improving, Osram and Philips have been making them more efficient. So they are the same wattage rating and fit directly into your car with zero modification. The best at the moment is the Osram Night Breaker I mentioned above, it is classed as a +90% bulb. This means it have 90% more lumens than a standard halogen, so this will give it a rough rating of 2850 lumens. Impressive really thinking it is just a halogen, plus a lot cheaper than a HID install. So if your car comes with the correct fitting for them I would strongly suggest them due to the performance to price ratio.
Sorry, clicked the buy button and the Philips lights were included for free as a separate item. Mental blockage.
What a silly question, "why are there 4 bulbs in the box??" Stupid me
2850 lumens? Not bad.... I managed to get 4000 lumens from a Osram IRC bulb, but that was 65W overdriven to 120W+, and wouldn't fit into a car, so I put it in a maglight instead. :cool:
Anyway, as your driving a french car, I'd be tempted to check your wiring... ;) There no point in having amazing bulbs if they are only getting 10v or so.
My 205 has awful wiring, and my bulbs are noticeably brighter after running a feed straight from the battery... A cheap and simple mod - all you need is wire, a fuse and relay. :)
EDIT: What's the bulb hour rating on the Night Breakers? Hotter bulbs tend to have a shorter lifetime as a rule of thumb...
EDIT2: To save me starting a new thread... Anyone know a ballpark figure of the amount of lumens that the 35W HID's output? I'm guessing around 3500 or so?
Not sure, only one way to find out! Sidelights seem to be very universal.
Edit - Looks like yours takes R5W, so no they won't fit.
MikeHunt79, Got more info on the wiring etc needed to do a direct feed from battery to bulbs? Does that mean that the stalk/switches for the lights in the car are just signal so no load going through them? If so, I know my Dolomite struggles a little with these new bulbs.
Not sure on the hour rating, Osram don't seem to show it. Shouldn't be too bad though.
For a 35W, you are talking about 3000-3500 depending mainly on the temperature of the bulb.
They're very good... I just put a set in to replace some older Osram Silverstars (which were also very good) and they're a noticable upgrade. Yes they're expensive but it doesn't make much sense to buy anything less good for a £10 saving IMO.
Just seen the Night Breakers for less than £20 on e-bay - I'm very tempted... :) I think they bulbs are going to be pretty durable for car use, but I'll keep a standard pair of H4's in the glovebox just in case...
3000-3500 sounds about right as I have seen HID's that claim to be 100 lumens per watt...
As for the direct feed, yes you are right... it doesn't draw load thru the stalks, it just uses them for a signal...
Gimmie a min and I'll post a diagram....
EDIT: Have a look at this... http://www.coloradok5.com/wiringlights.shtml
