- 29 May 2005
- West London
With 4 SATA drives, 1 optical. Might go get another tommorrow if I have time if it is fine.
With 4 SATA drives, 1 optical. Might go get another tommorrow if I have time if it is fine.![]()
Probably run 3 of them np!
My 720W says it can run 18 drives no problem. And thats including multiple graphics cards. The Corsair is only 70W less!
That's because with a full system as well as the two cards, you would be perilously close to 520W.
Jumping on the thread so i'll keep it short; putting together a q6600/8800GT/1 raptor 1 750gb/IP35 pro/Auzen Prelude/6400 crucial' ram.
I was gonna get the 520Corsair HX but then I thought I might get one of the higher end nvidia 9800 series next year, would it be wiser to spend the extra £30 for the 620W or should I be safe either way with 520, cheers !![]()
